8710 Blade Capacity
If 8710 blade is in remotely managed mode,the maximum capacity per blade is achieved with 12 screen licenses giving 12 x FullHD or 24 x HD or 48 x SD (w448p/480p30) or 96 x 360p resources. And 4 blades could be clustered. So the maximum ports are supposed to be 96x4 (384). But in the data sheet, there is a note: "Up to 104 calls are supported in one cluster of blades" .  What does it mean? even if the blades are clustered, the maximum capacity is 104 participants? Regardless of 96x4 ?
  • TelePresence
Bronze
8710 Blade Capacity
which document are you referring to (link)? because you can cluster up 3 blades at any time (not 4).
8710 Blade Capacity
At the end of the link explanation is given .
* 104 is the maximum number of calls that is possible on a TelePresence Server.
This is by design .
Kind regards,
Dharmmesh
8710 Blade Capacity
Bronze
8710 Blade Capacity
Thanks for the link. yes, you were right 4 blades for 8710 and 3 blades for 8510 cluster.
8510 blades were also clustered as 4 but for some reason is 3 now.
I think you saw Dharmmesh's response to your inquiry.
regards, Ahmad
685
