add phonebook number through web
Hey, guys
Do you know how to add some phonebook numbers through web used C endpoint? Note: there is no TMS.
One way may be create a XML txt?
Thanks!
Hunk
Hi Han Wu
No you cannot add contatcs via the webinterface.
C-series does not store phonebooks locally on the endpoint compared to the MXP. The C-series is using search only, direct lookups. The reason for this is scalability.
However if you do not have more than 100 entries there is one option you can use via XML. On the C-series there is a file called pb.xml which contains all the local contacts that are created on the endpoint it self. You can edit this file with all the contacts you need (up to 100) and upload the file + reboot the codec.
This is the only alternative, else I suggest that you aquire TMS managment for your endpoints as phonebook management will be much more easier.
The pb.xml file is located in /config of the endpoint. Just log into the endpoint via SCP as root. Here is an example of two entries in pb.xml:
    Entry 1
        11111111
        H323
        768
    User Name
        user.name@domain.com
        H323
        768
Hope this helps.
/Magnus
Re: add phonebook number through web
I get it. Thanks a lot !
Hunk
368
