Additional microphones for CTS 1100
Do you know how many additional Microphones can a CTS 1100 support ?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi Omar,The Phone Profile for
Hi Omar,
The Phone Profile for the CTS-1100 in CUCM will support 1 or 2.  The second microphone would be connected to the AEB center mic port 3 (Green port 3).
From the Installation Guide:
Optionally, you can install the second microphone on the opposite side of the table to provide full-table microphone coverage for audio-only conferences. If you install the second microphone, install it 18 inches (46 cm) from the edge of the table that is closest to the CTS 1100.
http://www.cisco.com/c/en/us/td/docs/telepresence/cts_1100/cts_1100_assembly_guide/cts_1100_assembly_guide/1100_installing_mount_and_display.html
In this case, the second microphone would be used for Audio Only Conferences.
- Jonathan
1 REPLY
Hi Omar,
- Jonathan
61
