Advise on Edge 95
I would like to know more about Edge 95 especially on "4 video conferencing and 3 audio conferencing" part
How does it work? does it include 4 video and 3 audio at the same time?
We have a client requesting for Edge 95
I'm aware that it is already EOL and the replacement is SX20.
But SX20 does not cover all the features of Edge 95, such as BRI and connector (RCA, S-Video)
So i'm thinking of SX20 / C40 + ISDN Link. (Quick question: which one is near to Edge 95 features, SX20 or C40?)
But i'm not sure on audio conferencing part. Please help on audio part.
Need your advise on this
Please advise
Best Regards,
Syahrir Mohamed Yatim
2 ACCEPTED SOLUTIONS
VIP Green
Advise on Edge 95
Yep, that's correct - the multi-site licence allows you to have youself + three additional participants - you cannot have a total of 7 - unless you use some form of MCU.
The older Edge MXPs could do the full 7 (youself and three others via video, and 3 additional audio - as long as everything was within the 2304kbpds bandwidth limitation), but as you mentioned, the Edge 95MXPs went End-of-Sale on 14 May 2013 so are no longer available.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
VIP Green
Advise on Edge 95
Yes,
With a C40, and the Multi-Site licence, you should be able to support youself, + three other video participants, + 1 audio call.  I have just dialled this combination myself on a unit here (C60) to double check this and can confirm it worked.
Wayne
Wayne
VIP Green
Advise on Edge 95
The SX20 is a quickset box - meaning the connectors and integration options are much more limited than something like the C40/C60.
You are correct that the Cisco TelePresence ISDN Link paired with either device will give you the required ISDN/BRI access.
You can have 2 video (yourself and another) and one additonal audio participant out of the box.  A multi-site licence key is required for more than that (the same occurred with the Edge 95s), up to a maximum of 4 video participants (yourself + 3 others).
Wayne
Wayne
Advise on Edge 95
Hi Wayne
Thanks for your reply
Quick question
Does it mean that "4 video conferencing and 3 audio conferencing" is not in same conference? It is either 4 video call or 3 audio call only and not both, right?
I'm a bit confused on that part. Please help me on to clarify
Best regards
SYahrir Mohamed Yatim
VIP Green
Advise on Edge 95
Wayne
Wayne
Advise on Edge 95
Hi Wayne
Thanks for the answer.
It clears my doubt on Edge95.
I'll probably go with C40.
If i use CTS-INTP-C40-K9 installed with MS license, am i correct in saying that it support (myself + 3 other video call + 1 audio call).
Best Regards
VIP Green
Advise on Edge 95
Yes,
Wayne
Wayne
Advise on Edge 95
Hi Wayne
Thanks for your answer and help
Appreciate it very much.
Best Regards
342
