Community Member
Audio only and no video between two CTS systems
I have a CTS3000 and a CTS1000. The call between these two systems is established as an audio only call, unless I configure the CTS systems to auto answer the calls. Speakerphone is disabled on both IP Phones. Any ideas why this happens?
Evi.
1 REPLY
Green
Re: Audio only and no video between two CTS systems
Hi Evi,
That looks a config issue
Since it is SHARED line, for 2 CTS system you will have only 2 Directory numbers, in your case, should be OFF in all (1 DN, shared b/w IP Phone and CTS).
In CTS Device web page select: CTS Auto AnswerRequired Field follow DN settings
How are you answering the call? using Midlet or using IP Phone?
425
作成コンテンツを作成するには してください
