Audio Science microphone placement
Daniel Isham
Level 4
Level 4
Does anybody know the range of this microphone besides just the front max distance that is documented? We have a pretty wide room where we swapping out a 1310 with a C90, and the screens are already in place. The room is about 40' wide and 30' long.
Wayne DeNardi
For a room that size, you'd be best looking at spreading multiple microphones around the room to capture the audio from all positions adequately (and at similar volume levels).  As the C90 allows up to 8 microphones to be direcly connected, it's designed for that sort of thing.  Alternately, you could run all the mics in the room back to a central mixer/dsp and then send a single feed in to the codec (we do this for most of our larger rooms).
As a general rule of thumb with the AudioScience microphones, we tell people to be within a 2m (6.5') radius for the best/consistent audio levels - obviously someone closer to the microphone will appear louder than someone further away - this can be lessened with the use of multiple mics as above..
There's some more information in this thread: https://supportforums.cisco.com/discussion/12093081/coverage-range-c40-default-onmidirectional-microphone
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
