Bandwidth Usage on telepresence point to point MX200
hi
what is the bandwidth usage on telepresence call point to point if i want use MX200 in both site?, i´ve one link 5MB
between both sites.
thansk
JCA
Magnus Ohm
You can do up to 6mbps point to point using 2 mx200 (5 in your scenario). You can choose the bandwith you prefer to use in the endpoint config gui.
For the actual bandwidth used you must (while in a call) enable the overview. Here you will see the actual bitrate.
/magnus
thanks for you help
another questions, this product MX200 can integrate with webex services.?
JCA
Hi Juan,
I don't think there is any way through which you can directly integrated MX200 with webex.
Vivek
There will be more of these integrations in the upcoming time, but for now it's not fully optimized yet.
/Magnus
