BANNER
If possible may I get information on the procedure to customize and update the VCS banner.  Ofcourse it will state "powered by CISCO"
thank you.
Chet Cronin
Chet Cronin
801-815-3539(USA)
801-815-3539 (AFG)
BANNER
Hi. Before asking questions its a good idea to search in the forum or with your favorite
search engine and also consult the documentation and the online help.
http://www.cisco.com/en/US/products/ps11337/prod_maintenance_guides_list.html
If you refer to the text yousee ont he http login page:
(from the vcs onlint help)
Configuring the Login page
The Login page configuration page (System > Login page) is used to specify a message and image to appear on the login page for both users and administrators.
The Welcome message title and text will appear to administrators when attempting to log in using the CLI, and to FindMe users and administrators when attempting to log in using the web interface.
You can upload an image that will appear on the login page, above the welcome message, to FindMe users and administrators when attempting to log in using the web interface.
    supported image file formats are JPG, GIF and PNG
    images larger than 200x200 pixels will be scaled down
If the VCS is using the TMS Provisioning Extension services to provide user account data, then users log into their FindMe accounts through TMS, not through VCS.
Please remember to rate helpful responses and identify helpful or correct answers.
BANNER
I am sorry wasn't clear enough.  I got the login page down with no issues.  it's the top banner after the login that I want to change.   I am able to mod the banner on the TMS server with no issue.  It's the Banner on the VCS server ... I figure going to have to login root and get the banner file and than put it back after customizing but would like to know where to find it ...
thank you
Chet Cronin
801-815-3539(USA)
+9379 601-3954 (Afghanistan)
Chet Cronin
801-815-3539(USA)
801-815-3539 (AFG)
BANNER
Hi Chet,
The banner cannot be changed. It is not an image file.
Guy
BANNER
Roger that... Thank you.
Chet Cronin
801-815-3539(USA)
Chet Cronin
801-815-3539(USA)
801-815-3539 (AFG)
257
