Best way to separate the endspoints and Movi/Jabber
BW Dijk
Hello
I'm working on a tipical VCS c & VCSe configuration with TMS & movi
I have 3 IP ranges (office locations).
To separate the these locations I created 3 Subzones using Subzone membership rules. This works for the endpoits.
But I have trouble to make the autentication of the movi users work, they can register to the VCS but the passwords don't work
What is the best way to have movi clients register in regard with
- Default Zone             Do not check credentials - Treat as authenticated or Check credentials
- Default Subzone       Do not check credentials - Treat as authenticated or Check credentials
- Subzones                Do not check credentials - Treat as authenticated or Check credentials
What is the best and easiest way to separate the endpoints from the movi clients, all units are on the same IP range end subnet.
So that autentication of the movi users work and that the endpoits can register
Best regards,
Bert-Wietze
Patrick Pettit
HI Bert - If you want to try and put MOVI into one subzone on VCS, try REGEX pattern to match to the device URI pattern you have in TMS.
So we have a MOVI subzone allocated on our lab VCS with subzone membership rule: (.*).movi@tacsupport.lab
Device URI in TMS is set to the following for MOVI: {username}.{device.model}@tacsupport.lab
We set this MOVI subzone to check credentials, and when running a log, you *should* see the 401 Unauthorized and then the re-subscribe with MOVI sending the credentials.
Give it a shot and let us know if this works for you.
VR
Patrick
Alok Jaiswal
In addition to what patrick has said, i would suggest followoing settings for your scenario.
Default zone  -- check credentials --> necessary as all initial subscribe would be passed through this zone and will be challenged for credentials. If you set it to "treat as authenticated" any password would work.
Default subzone for MOVI -- check credentials or treat as authenticated as phonebook or presence requires this to be authenticated.
Subzone for endpoint -- Treat as authenticated -- so that if you do not use the authentication  for registration your registration should work.
Also creating different subzones will allow you to manage bandwidth proeprly.
Alok
Hello Alok and Patrick,
I got it done and it works fine, thanks for the answers.
Best regards,
Bert-Wietze
