BFCP from MCU for encrypted calls
I know this has been discussed before regarding the CUCM in particular earlier this year:
https://supportforums.cisco.com/message/4001153#4001153
We have a set up using VCS (7.2), Conductor (2.2) and MCU (4.4) where we need SIP content on encrypted calls for dual-display systems using BFCP because Conductor is SIP only.  It's not acceptable to disable encyrption on the MCU for all types of calls as a workaround.
From the 4.4 release notes:
Binary Floor Control Protocol on encrypted calls:
The transmission of SIP content from the MCU using Binary Floor Control Protocol (BFCP) is not supported on encrypted calls. To allow content to be transmitted over SIP calls in a separate channel from main video, you should disable encryption on the MCU or on the target endpoint.
Is anyone aware of a planned fix for this?
Many thanks
Trevyn
Everyone's tags (4)
1 ACCEPTED SOLUTION
I think the target for this implementation will be in 4.5.  The date of which this release will be public is August (Tentative), but the SW is currently EFT, so you can maybe sign up and test it out if you wish.
VR
Patrick
1 REPLY
VR
Patrick
297
