c-60 --- 2nd & 3rd camera concern
shuja.javed
We have to install 3 cameras on C-60 codec........the arrangemnt is as follows
First camera --- on HDMI port
Second camera ---- on HDMI port
Third Camera  ------- on DVI port via DVI-HDMI convertor
On going to the camera settings option...........we are getting only two options ''PRIMARY Cam & SECONDRY CAMERA ''  no where there is the option of third camera ..........
we have tried by connceting second camera on DVI port .........but upon connecting the BLACK IMAGE is found.........however on HDMI port camera is working fine,,,,,,,,,
pl share if there is any special setting/configuration changes needs to be done for using third camera on DVI port.........or my problem cause is somthng else
KIndly answer.......
Wayne DeNardi
Hav you set the three source connectors correctly?
Configuration > System Configuration > Video
Set Source 1 Connector to HDMI
Set Source 2 Conenctor to HDMI
Set Source 3 Connector to DVI
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
