C20 Issue
Omar Abdelhalim
Dear All,
I have C20 Unit, there's no video out and onceI hvae to access the web interface I got the message:Web Interface C20.jpg
  If I use the telnet to access the unit i got the message:
please, advice me how to solve this problem.
Thanks All
Omar Mahmoud
9 Replies 9
Martin Koch
If the system has an active service contract I would escalate this thread to Cisco TAC.
You can also find some more info here:
https://supportforums.cisco.com/message/3512554#3512554
In general I would try to boot up with the second software image and there is also a way to
flash the firmware from tftp.
Did you enable telnet or do you have the non encrypted software version?
If doing upgrades please also always check that you use the right version (with / without encryption)
Martin
Magnus Ohm
Hi Omar
You could try to factory reset the system:
1) When powered down, pressing the power switch for fifteen seconds (until the green LED in the front of the system turns red.)
2) Now confirm the reset by two short presses within the next five seconds.
Hope this helps
/Magnus
vivsing2
Hi Omar,
Since your device is C20, I am sure Serial will not possible, so i think you will not be able to take help from discussion https://supportforums.cisco.com/message/3512554#3512554
So I would prefer changing it's software image, if it contain two software image, take telnet/ssh and login with "root" and then type command "selectsw"
and check whether image1 is active or image 2 is active and then select image which is not active, so for example image2 is not active, then type command "selectsw image2"
Vivek
I never checked if the serial port for the camera also allows a login, anyhow, with a special/y cable its
possible to connect to the serial control port of the C20. A pin layout is described here:
http://developer.tandberg.com/web/guest/forum/-/message_boards/message/28778#_19_message_28844
   C20 to   Std. RS.232
   Pin 1-------------------Pin2
   Pin 5-------------------Pin5
   Pin 6-------------------Pin3
I guess the factroty default reset mentioned by Magnus is a good start.
Martin
I checked camera serial port will not be able to help to login.
Yes you are right there is cable, normally customer don't have special cable which is Y cable. So I hope Omar can try making cable and then take serial connection
Vivek
Omar Abdelhalim
Thanks All,
i'll try to make this cable and the next step to reset the unit to the factory reset.
and check the software imgae active.
Omar Mahmoud
Hi Omar,
you could try the FacDef also without the cable, but sure, always nice to see some debug messages,
also to try to boot the other soft or as an input for TAC.
Good success!
Omar Abdelhalim
Hi Martin,
Sorry, what FacDef, and how can i use it to solve this issue.
The Factrory default reset.
