C90 and TRC V issues
I am see the following issues with a three camera C90 system.
How to stop a C90 system TRC V menu button press from causing the volume to decrease?
When activating the standby mode with the TRC V the system immediately wakes back up.
Tried both 1 and multiple cameras with IR sensor enabled.
  • TelePresence
2 ACCEPTED SOLUTIONS
VIP Green
Erratic remote control
Erratic remote control behavior can often be seen when the batteries in the remote start getting low.  Have you tried replacing them with new, fresh batteries?
Hi, This is probably caused
This is probably caused by a low battery in your trc remote. Try to look at the ir sensor when you press a button, you should see it pulsating twice if this is the matter. The reason for the 'double-pulse' is that the TRC are originally designed for MXP codec which do support low battery warnings, so when the C90 gets this pulse it misinterpret it as volume going down.
tip: put the remote in front of the camera to see the pulses, you can compare working and non working remote
//Marius
VIP Purple
Hello Joel -Which menu button
Hello Joel -
Which menu button are you pressing that is affecting the volume level?
The TRC remove has sensors on the side, if you notice down the edge of the remove where joint is, there are rubber strips down each side.  If you put the codec into standby and are still holding the remote after a brief period of time (don't know the period of time) where the sensors are, you will wake it back up.
The button causing the volume
The button causing the volume to decrease is the center "check mark" which is used to open the menu or accept changes.
I am aware of the rubber strips and I am attempting the forced standby without touching the strips.
Also no other IR sources in the room.
I should try disabling the camera IR receivers and enable the codec IR to see if issues are the same.
VIP Purple
You could log into the codec
You could log into the codec via SSH and see what the codec's IRsensor is receiving is doing in response to the remote.
log ctx IRsensor debug 9
log output on
VIP Green
Thanks for the pointer, this
Thanks for the pointer, this was a battery issue. One battery was put in backwards. I should have tried a different remote.
//Marius
To clarifiy, Are you saying
To clarifiy, Are you saying the Camera green LED that indicates IR reception, will double flash whenever the battery is getting low?
312
