CAB-VGA-DVI-AUD25=
I have a problem regarding the presentation cable Part ID: CAB-VGA-DVI-AUD25 This cable used to be this config
DVI           ->       VGA
RCA         ->       3.5 mm stereo
But now (since this summer 2014) its seams to be this config on the cable:
DVI            ->      VGA
3.5 mm     ->      3.5 mm
Has anyone had this issue when doing an RMA?
I just want to know witch presentation cable is for C-codecs now?
/Jonas
VIP Green
There's a description of the
There's a description of the cables in this thread and some options for sourcing cheaper ones.
But, to quickly answer your question
  • CAB-VGA-DVI-AUD25= should have one end RCA and the other the 3.5mm.
  • CAB-VGA-DVI-AUD= would be the one with 3.5mm jack at both ends.
So, if you're doing an RMA, it's possble you're requesting, or being sent, the wrong cable as a replacement.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Hi,This is what i got when i
This is what i got when i order the CAB-VGA-DVI-AUD25.
This was not the case before the summer but i have not get any information from Cisco on a new Part ID.
As you can see in this picture it is the wrong part with this part ID: CAB-VGA-DVI-AUD25
599
