Community Member
Cable specification for CTS3010 and CEILING VISUALIZER VZ-C32 (WOLFVISION) Doubt
Hi to all
Can you confirm the cable specification to connect the Document Camera to the CODEC and which way round it needs to go?
As I understand it we need a DVI (Camera end) to HDMI (CODEC end) cable plus one CAT5/CAT6 cable.  Can you please clarify?
Best regards
1 ACCEPTED SOLUTION
Hello Alberto,
You are correct.  You will need an ethernet cable (CAT5 is fine) from the camera to the primary codec as well as a DVI-HDMI video cable from the camera to the primary codec.
HTH,
Paula
1 REPLY
Hello Alberto,
HTH,
Paula
305
