calls not completing to 9971 from VCS side
I have an unusual issue here.
CUCM - 7.1.3
VCS - 6X
9971 - 9.0
C60 - TC4.1.0
Call from C60's registered with VCS as H323 endpoints can not call across a SIP trunk to 9971 video phones registered as SIP endpoints on CUCM. Working with TAC and have identified this as a reason for the call setup failure.
12/07/2011 23:43:15.232 CCM|//SIP/SIPTcp/wait_SdlReadRsp: Incoming SIP TCP message from 10.248.19.1 on port 25478 index 36892 with 901 bytes:
INVITE sip:6661@10.248.0.10:5060 SIP/2.0
Via: SIP/2.0/TCP 10.248.19.1:5060;egress-zone=CUCMNeighbor;branch=z9hG4bK65139289f83b39ba650c074268d456fc41137.9ea38c26ce6e045c7fe529277702b25c;proxy-call-id=241dd556-2157-11e1-aa11-0010f31ed988;rport
Via: SIP/2.0/TCP 127.0.0.1;branch=z9hG4bK4f41519ef9157d4534e93b8683e06e4441136
Call-ID: 783a734a27f88f23@127.0.0.1
CSeq: 52592 INVITE
Contact: <sip:4128591799@10.248.19.1>
From: <sip:4128591799@10.248.19.1>;tag=022bae8c5131cfc7
To: <sip:6661@10.248.0.10:5060>
Max-Forwards: 15
Record-Route: <sip:proxy-call-id=241dd556-2157-11e1-aa11-0010f31ed988@10.248.19.1:5060;transport=tcp;lr>
Allow: INVITE,ACK,BYE,REFER,INFO
User-Agent: TANDBERG/4100 (X6.1)
Supported: com.tandberg.sdp.extensions.v1
Require: com.tandberg.sdp.bfcp.udp,com.tandberg.sdp.duo.enable
Session-Expires: 1800
X-TAATag: 241dd678-2157-11e1-a750-0010f31ed988
Content-Length: 0
12/07/2011 23:43:15.232 CCM|//SIP/Stack/Error/0xb4456168/Bad Extension - Require header processing failed.|<CLID::StandAloneCluster><NID::10.248.0.11><CT::2,100,45,1.68627><IP::10.248.19.1><DEV::><LVL::Error><MASK::40000>
So it's having an issue with:
12/07/2011 23:43:15.233 CCM|//SIP/SIPTcp/wait_SdlSPISignal: Outgoing SIP TCP message to 10.248.19.1 on port 25478 index 36892
SIP/2.0 420 Bad Extension
Date: Thu, 08 Dec 2011 04:43:15 GMT
Allow-Events: presence
Content-Length: 0
To: <sip:6661@10.248.0.10:5060>;tag=2070562717
Via: SIP/2.0/TCP 10.248.19.1:5060;egress-zone=CUCMNeighbor;branch=z9hG4bK65139289f83b39ba650c074268d456fc41137.9ea38c26ce6e045c7fe529277702b25c;proxy-call-id=241dd556-2157-11e1-aa11-0010f31ed988;rport,SIP/2.0/TCP 127.0.0.1;branch=z9hG4bK4f41519ef9157d4534e93b8683e06e4441136
CSeq: 52592 INVITE
Unsupported: com.tandberg.sdp.bfcp.udp,com.tandberg.sdp.duo.enable
Has anyone seen this before?
If so, what specifically is needed to resolve?
thanks,
rob
On the VCS: Protocols --->SIP--->Configuration
Try turn off "Require duo video mode"
cheers jens
Please rate replies and mark question(s) as "answered" if applicable.
To have a better understanding of what's going wrong here can you please provide the following from VCS
xconfiguration
xstatus
netlog 2
place a call to reproduce the issue
netlog off
Also kindly asked to make sure that you follow the steps described in the VCS / CUCM deployment guide
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Cisco_Unified_Communications_Manager_Deployment_Guide_CUCM_6-1_7_8_and_X6.pdf
Check the CUCM Trunk settings ( ie...  Media Termination Point Required settings ( disabled if you are placing video calls )
If still not working kindly asked the logs provided
Cristian
HI Rob - You should see an ACK to this 420 and see VCS Re-Invite the call WITHOUT the required extensions in the empty Invite.  Do you see that in the CUCM trace?  Can you look passed this to see if you see that behavior?
From what I've seen VCS should re-Invite the call without those extensions. Is there any other dialog happening after this occurs? Does the call fail or does it connect with no audio or video? I do believe the call ID tag will change when this occurs, but I may be mistaken.
VR
Patrick
First off, thank you for the suggestions above.
It was resolved by turning off one of the default SIP trunk settings in CUCM 7.1.3.
Whoever has ownership of this doc
may wish to add that you need to unselect
Use Trusted Relay Point*
1579
