10-24-2013 12:23 AM - edited 03-18-2019 02:01 AM
Hi!
I have Tandberg 150 MXP firmware version L4.2.
I can't upgrade version L5 from L4.2. When i upgraded L.4.2 was succeed.
But, If i try firmware L5 or L6 can't upgrade with message popup "System ugrade failed!".
How can i upgrade to firmware version L5 or L6 from L4.
Thank You!
Solved! Go to Solution.
10-24-2013 04:33 PM
From that screen shot, you are unable to get anything other than the L4.x key as you do not have an active service contract on that device (Service Contract number and end dates are "null"). As mentioned above, you can only get the newer release keys with a valid service contract. To get the upgrade, you will need to take out a service contract through your local Cisco Partner. If you believe that you do have an active service contract on your device, but it is now showing as such on the portal, I suggest you contact the TAC with the evidence that you have purchased one and they may be able to assist.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
10-27-2013 05:10 PM
If you haven't seen the PM or email from Craig, he's likely referring to this Cisco Security Advisory from September 2011 http://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20110831-tandberg.
You may be able to get a free upgrade/licence key (to version F9.1) through the TAC for your 1000MXP. See the section "Customers Without Service Contracts" under "Obtaining Fixed Software".
Wayne
10-24-2013 03:47 PM
You will need a valid release key for the firmware version you are trying to upload - without this, the upgrade will fail.
The steps to perform the upgrade are relatively sinple:
1) Log in to the web interface as admin
2) Click Software Upgrade.
3) Enter the new release key in the Release Key field.
4) Click Install Software and browse to the location of your upgrade file (ie s51001l6_1.pkg).
5) Click the Install button
If you connect to the command line interface of your device via telnet before clicking the Install button, you can watch the progress of the upgrade.
Wayne
10-24-2013 04:03 PM
I have valid release key from CISCO and trying to same step but, same message popup "System upgrade failed".
When i downgraded L4.0 from L4.2, I can upgraded to firmware.
Also i can upgrade firmware L4.2 from L4.0.
But, firmware L5 version can't upgrade.
Thank You for the answer!
10-24-2013 04:15 PM
The upgrade from L4.0 to L4.2 will work as it's a minor version upgrade, so will use the same release key (ie, an L4.x key).
If you want to upgrade to L5.x or L6.x, you will need the release key for that specific software version. The L4.x key will not work. You can get this new key from the TAC, or the Licencing Portal if you have a valid service contract.
Wayne
10-24-2013 04:24 PM
I can't choose other version, only version L4.2 from upgrade to menu.
How can found other version release key ?
10-24-2013 04:33 PM
Wayne
10-24-2013 04:41 PM
Thank you for the correct answer!
Have a nice day!
10-24-2013 05:01 PM
Chin I just sent you a private message that may interest you.
Goodluck!
10-24-2013 05:13 PM
Upton,
I'm not recevied private message from you!
Please send email me below the email.
Thank You!
V/R
10-27-2013 05:10 PM
Wayne
03-28-2018 06:39 AM
Dear coleagues,
Please consult if you succeeded in getting the release key for TANDBERG 150 MXP ver 5.0.
Best regards,
Anton
