Changing Hostname in CTS-MAN
Our CTS-MAN server software has been loaded but we haven't configured it yet for use. Is there a way to change the HOSTNAME? I've tried the CLI command SET NETWORK HOSTNAME which seems to work and causes a restart, but after it comes back up the web interface is inaccessible (using IP address as before). I have to use the CLI command to change the HOSTNAME back to the original before I can access it via the web interface again. We've got version 1.5.0.0-384 running.
1 ACCEPTED SOLUTION
Green
Re: Changing Hostname in CTS-MAN
Not supported, we need to reinstall
Green
Yes, installing 1.6.0.0 from scratch (.iso) allowed my to set the hostname properly. Thank-you.
619
