CISCO C60 Codec
the system does not start up, potentially it is stuck in bootloop. At the start there only appears shortly the CISCO Logo. I will send my contacts by mail now a log for review.
Everyone's tags (5)
1 REPLY
CISCO C60 Codec
I looked at the log you sent via email. The codec boots as far as the login prompt, but then apparently reboots.
login:
U-Boot 2010.06-89 (Aug 10 2011 - 14:36:51) MPC83XX
Reset Status:
CPU:   e300c1, MPC8347_TBGA_EA, Rev: 3.0 at 600 MHz, CSB: 200 MHz
I2C:   ready
DRAM:  DDR2 RAM: 512 MiB
RAM data bus test          [PASS]
RAM address bus test          [PASS]
Either the main application crashes or there's some hardware issue.
Since you have console access I would let the codec reboot and enter followed by at reboot.
Press 'b' to enter u-boot prompt
Press 'c' to stop autoboot:  0
The you should get the u-boot prompt.
From there, we need to set some environment parameters so the codec does not reboot when it crashes and we can access the root shell to get the logfiles.
CASPER>setenv othbootargs allowroot noboot
CASPER>boot
Now when there's a crash, it should not reboot.
login as root and get all the logfiles
tar -cvf /tmp/historical_log_bundle_tar /config/logs/*
gzip /tmp/historical_log_bundle.tar
scp /tmp/historical_log_bundle.tar.gz user@system:historical_log_bundle.tar.gz
Last is secure copy to get file from your codec to some unix system.
You can also use winscp or some other program to get the file of the codec so it can be sent over.
If there are crashes, we should be able to run the files through a tool to look for known issues.
That would be the first step.
Also, at the CASPER> prompt, collect the output of hwmon :
CASPER>hwmon
That will show the voltages are in spec or not.
If you can get these files, that would be great!
Another way of looking at error messages would be to use following procedures, ones you broke into u-boot.
CASPER> setenv othbootargs allowroot noconsolefile noboot timestamp
CASPER>setenv console ttyS0
CASPER>boot
Now all the logging info is sent straight to your console.
Good luck,
Danny.
294
