Cisco MCU MSE 8510 - guest PIN doesn't work
We have few conferences setup on the 8510 blade. Each conference has the main PIN and the Guest PIN configured. When I dial into the conference, main PIN works fine but the guest PIN doesn't work.
I tried dialing in with the PIN from one endpoint, and then with the guest PIN from the other endpoint but the conference doesn't accept guest PIN. I can use the main PIN on both endpoints though.
Does anyone know what the issue may be?
Everyone's tags (2)
1 ACCEPTED SOLUTION
VIP Purple
I just tested this without
I just tested this without 8510, no issues at all.
Can you give us a screenshot of how your conference is configured?
I had used the same Numeric ID for both chair and guest, with a different PIN for each.  When I connected as chair, I went straight in.  When I connected as guest, I went straight in, however I got a prompt saying saying on chairman to arrive or connect.
VIP Purple
The issue is now resolved:
The issue is now resolved: Guest Numeric ID field was empty. Thanks for the advice!
90
