Cisco Remote Control
                   hello
Is it possible to turn off C60 codec with the remote control?
Sheryl Brown-CCENT
1 ACCEPTED SOLUTION
VIP Purple
Sheryl -
Do you want to put the C60 a sleep, or turn the power off?
It's not possible to turn the power off via the remote.  However you can put it to sleep by holding the red end call button down for serveral seconds, a popup will appear with the option to then do so.
Hi Sheryl,
This community is dedicated to Cisco Unified MeetingPlace and Cisco WebEx Meetings Servers.I advise you to post this question in Telepresence community which is observed by Telepresence experts in order to get the answer to your question.
I hope this helps.
-Dejan
thank you for your advisement
Sheryl Brown-CCENT
VIP Purple
Sheryl -
Patrick,
You answered both my questions. Thanks for your response!
Sheryl Brown-CCENT
221
