CISCO SX20 codec issue
Hi all,
I have a SX20 system and its codec seems to never boot up,
The power button LED blinks slowly,
The Ethernet connection doesnt work,
There is neither video signal nor audio,
It seems to be in standby mode but ir never wakes up,
I cant access to the web interface,
I also tried to reset it using the power button,
Thanks in advance,
1 ACCEPTED SOLUTION
VIP Green
You could try connecting to
You could try connecting to the SX20 with a serial connection (See this thread for some options - Post 8 by Tanja Bader) and see if you are able to see any messages on the console.
Failing that, it sounds like you might need to RMA the device.
Wayne
Please remember tor rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
VIP Green
Wayne
Wayne
Have you tried the factory
Have you tried the factory reset?
Turn off SX20, then hold the power button for 10 seconds until it starts blinking. Then press the power button twice. SX20 should factory reset  and restart automatically.
If this does not work, RMA the device.
Ulderico
Hi,Thanks for the answers,I
I tried to reset the codec but it doesnt work,
I dont have those cables needed to troubleshoot it,
I'll RMA the device,
Thanks for the advices,
Regards...
323
