Cisco SX20 Quick Set Telepresence first time connection
Hi all,
I have a Cisco SX20 Quick Set Telepresence, that I just unpacked, installed physically and configured the IP address.
I'm certain that I'm missing some part of the initial configuration, because although the system is physically connected through the network to another Video Conference system (SONY PCS-XG55, this Sony system works fine we had it for a long time now), when I make a call from the SX20 it doesn't connect, instead almost immediately stops the call processand it doesn't say anything on the screen. If I check the log, I find so much information that I'm not really sure what is useful and what is not.
Just to give you a hint I found this that could be useful: "MC ERROR: TransactionActionStorage::removeAction no match for Disconnect callstackid"
Additionally in the troubleshooting page using the web connection to the Cisco SX20 system I get the following error:
“WARNING: Default Call Protocol
The default call protocol is set to H323, but system is not registered on that protocol. The system may not be able to make any calls. Please either change the default call protocol, verify that the protocol is enabled, or verify the H323 configuration”.
Any ideas as to what am I missing will be appreciated.
Thanking you in advance,
Camilorg
Try This . . . Navigate to --
Try This . . .
Navigate to ---> H323 Profile [1..1] CallSetup Mode
The H.323 Call Setup Mode defines whether to use a Gatekeeper or Direct calling when
establishing H323 calls.
NOTE: Direct H.323 calls can be made even though the H.323 Call Setup Mode is set to
Gatekeeper.
Requires user role: ADMIN
Value space: <Direct/Gatekeeper>
Direct: An IP address must be used when dialing in order to make the H323 call.
Gatekeeper: The system will use a Gatekeeper to make a H.323 call. When selecting this
option the H323 Profile Gatekeeper Address and H323 Profile Gatekeeper Discovery
settings must also be configured
Hi ttrentler,I have made the
Hi ttrentler,
I have made the change you proposed, but still nothing, I can't establish the connection. Here it is the part of the log that was created when attempting the configuration (it is quite long):
Jun 10 14:58:38 a8 appl: 5802001.24 MainEvents I: ConferenceSessionCreated(c=13)
Jun 10 14:58:38 a8 appl: 5802001.25 MainEvents I: ActiveSpeakerIndication(c=13,p=1)
Jun 10 14:58:38 a8 appl: 5802001.25 MainEvents I: ParticipantJoinedConference(c=13,p=1)
Jun 10 14:58:38 a8 appl: 5802001.26 IxCtrl I: iXController(0x42e71684) registerProtocolUser: proto=1, user=0x42e71760
Jun 10 14:58:38 a8 appl: 5802001.26 MainEvents I: LayoutUpdated(p=1) outputNo=1 og=5
Jun 10 14:58:38 a8 appl: 5802001.26 MainEvents I: LayoutUpdated ...frame[GUI] gui p=1 src=0 ig=4 x=0 y=0 w=10000 h=10000 l=0 b=0 letterbox
Jun 10 14:58:38 a8 appl: 5802001.26 MainEvents I: LayoutUpdated ...frame[SelfviewPip] selfviewPip p=1 src=1 ig=2 x=7487 y=7499 w=2409 h=2409 l=5 b=1 snapBorder letterbox
Jun 10 14:58:38 a8 appl: 5802001.27 MainEvents I: LeavingStandby()
Jun 10 14:58:38 a8 appl: 5802001.27 MainEvents I: Mic Mute Enabled
Jun 10 14:58:38 a8 appl: 5802001.27 MainEvents I: OutgoingCallInvoked(p=14) remoteURI='h323:180.209.17.9' localURI='h323:180.209.48.30' bookingID=''
Jun 10 14:58:38 a8 appl: 5802001.31 CAMERA I: CamVisca::Ready_doCAMActionReq cameraId=1 actionId=1
Jun 10 14:58:38 a8 appl: 5802001.32 MediaStreamController I: MV::getVCSetting getOutputPortStatus initialized 1
Jun 10 14:58:38 a8 appl: 5802001.32 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 1 w 1920 h 1080
Jun 10 14:58:38 a8 appl: 5802001.32 VIDEOLC-0 I: PowerManagement, request power save off
Jun 10 14:58:38 a8 appl: 5802001.33 CAMERA I: CamVisca::Ready_doCAMActionReq cameraId=1 actionId=19
Jun 10 14:58:38 a8 appl: 5802001.33 DATACTRL I: DataGateAddReq(ig=179) assoc gate -1 hdlc=yes
Jun 10 14:58:38 a8 appl: 5802001.36 VIDEOROUTER-0 W: VideoRouter_Ready_doVIDDelayInd: No gateid 4 from FSPROXY_FSM 9
Jun 10 14:58:39 a8 appl: 5802001.46 VIDEOROUTER-0 W: VideoRouter_Ready_doVIDDelayInd: No gateid 4 from FSPROXY_FSM 9
Jun 10 14:58:39 a8 appl: 5802001.52 VIDEOROUTER-0 W: VideoRouter_Ready_doVIDDelayInd: No gateid 4 from FSPROXY_FSM 9
Jun 10 14:58:39 a8 appl: 5802001.57 VIDEOLC-0 I: PowerManagement, power save off confirmed, no error
Jun 10 14:58:39 a8 appl: 5802001.65 RTP I: TrafficCtrl: Added new entry (main): id: 98, tcid: 65568
Jun 10 14:58:39 a8 appl: 5802001.69 RTP I: TrafficCtrl: Added new entry (duo): id: 100, tcid: 65568
Jun 10 14:58:39 a8 appl: 5802001.71 MainEvents I: ParticipantJoinedConference(c=13,p=14)
Jun 10 14:58:39 a8 appl: 5802001.71 MC I: CallParticipant: calledUri: h323:180.209.17.9
Jun 10 14:58:39 a8 appl: 5802001.72 H323Call I: h323_call::makeOutgoingCall(p=14): Sending call request to stack (rate=512000 srcName='', src uri='h323:180.209.48.30' src e164='' dest='180.209.17.9')
Jun 10 14:58:39 a8 appl: 5802002.05 H323Call I: h323_call_handler::handleH323CallRej(p=14, s=1) Incoming call reject (Cause: 12:3, h323 cause: 3:18)
Jun 10 14:58:39 a8 appl: 5802002.05 MC ERROR: TransactionActionStorage::removeAction no match for Disconnect callstackid(14)
Jun 10 14:58:39 a8 appl: 5802002.06 MainEvents I: CallDisconnectRequested(p=14) remoteURI='h323:180.209.17.9' cause=[normal('') 'LocalDisconnect']
Jun 10 14:58:39 a8 appl: 5802002.06 MainEvents I: ParticipantLeftConference(c=13,p=14)
Jun 10 14:58:39 a8 appl: 5802002.07 MainEvents I: CallDisconnected(p=14) remoteURI='h323:180.209.17.9' causeToLocal=[fail_network_rejected('Unreachable destination') 'NetworkRejected'] causeToRemote=[normal('') 'LocalDisconnect']
Jun 10 14:58:39 a8 appl: 5802002.08 DATACTRL I: DataGateCfgReq(ig=179) hdlc=yes
Jun 10 14:58:39 a8 appl: 5802002.08 IXUser I: iXFsmHandler: deleteChannel(client=0x42e71684)
Jun 10 14:58:39 a8 appl: 5802002.08 IXUser W: iXFsmHandler: Could not find client 0x42e71684 to deleteChannel
Jun 10 14:58:39 a8 appl: 5802002.09 MC I: CapabilityControllerImpl::setCapset() reductionLevel = 0, waitForDuoGate = 0, hasLegacyVideo = 0
Jun 10 14:58:39 a8 appl: 5802002.09 MainEvents I: ConferenceSessionReleased(c=13)
Jun 10 14:58:39 a8 appl: 5802002.10 MainEvents I: LayoutUpdated(p=1) outputNo=1 og=5
Jun 10 14:58:39 a8 appl: 5802002.10 MainEvents I: LayoutUpdated ...frame[1.1] wallpaper p=1 src=0 ig=184 x=0 y=0 w=10000 h=10000 l=1 b=0 clip
Jun 10 14:58:39 a8 appl: 5802002.10 MainEvents I: LayoutUpdated ...frame[GUI] gui p=1 src=0 ig=4 x=0 y=0 w=10000 h=10000 l=0 b=0 letterbox
Jun 10 14:58:39 a8 appl: 5802002.10 MainEvents I: LayoutUpdated ...frame[SelfviewPip] selfviewPip p=1 src=1 ig=2 x=7487 y=7499 w=2409 h=2409 l=5 b=1 snapBorder letterbox
Jun 10 14:58:39 a8 appl: 5802002.10 MainEvents I: Mic Unmuted
Jun 10 14:58:39 a8 appl: 5802002.11 MainEvents I: Mic Mute Disabled
Jun 10 14:58:39 a8 appl: 5802002.11 RTP I: TrafficCtrl: Deleting entry (main): id: 98, tcid: 65568
Jun 10 14:58:39 a8 appl: 5802002.11 RTP I: TrafficCtrl: Deleting entry (duo): id: 100, tcid: 65568
Jun 10 14:58:39 a8 appl: 5802002.12 CAMERA I: CamVisca::Ready_doCAMActionReq cameraId=1 actionId=20
Jun 10 14:58:39 a8 appl: 5802002.12 MediaStreamController I: MV::getVCSetting getOutputPortStatus initialized 1
Jun 10 14:58:39 a8 appl: 5802002.12 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 1 w 1920 h 1080
Jun 10 14:58:39 a8 appl: 5802002.12 MC ERROR: TransactionActionStorage::removeAction no match for Modify  InGate  id(179)
Jun 10 14:58:39 a8 appl: 5802002.12 DATACTRL I: DataGateRemReq(ig=179)
Jun 10 14:58:39 a8 appl: 5802002.14 MediaStreamController W: doAUDIOCFGGATECNF(ms-ig=173) not found
Jun 10 14:58:39 a8 appl: 5802002.19 MediaStreamController I: doAUDIOMIXERREMGATECNF(ms-ig=173) not found
Jun 10 14:58:40 a8 appl: 5802002.50 RTP ERROR: find_by_index(sid=48) invalid index (session_counter = 52)
Jun 10 14:58:40 a8 appl: 5802002.51 RTP ERROR: find_by_index(sid=49) invalid index (session_counter = 52)
Jun 10 14:58:40 a8 appl: 5802002.65 RTP ERROR: find_by_index(sid=50) invalid index (session_counter = 52)
Jun 10 14:58:40 a8 vcodec: 5802002.33 DEC_FSM-0 I: create jpeg width=1920 height=1200 mbps=0 dec=ttvdec_mjpeg_ivahd
Jun 10 14:58:40 a8 vcodec: cq pair: mjpeg_dec-0 <-> cq_wt-0
Jun 10 14:58:40 a8 vcodec: Power up ivahd 0
Jun 10 14:58:40 a8 vcodec: Power up ivahd 0: completed in 89 us
Jun 10 14:58:40 a8 vcodec: Ivahd 0: Acquired after power down
Jun 10 14:58:40 a8 vcodec: setting max frame rate to 60
Jun 10 14:58:40 a8 appl: 5802002.69 RTP ERROR: find_by_index(sid=51) invalid index (session_counter = 52)
Jun 10 14:58:41 a8 vcodec: setting max frame rate to 30
Jun 10 14:58:41 a8 appl: 5802003.98 VIDSRCCTRL-0 I: HDMI format change vidIo event - 1920x1080@60Hz
Jun 10 14:58:41 a8 appl: 5802003.98 VIDEOLC-0 I: VLC_readySignalSourceEvent port:HDMI 1: have signal
Jun 10 14:58:41 a8 appl: 5802004.01 VIDSRCCTRL-0 I: vidIo: accept digital input timings 1920 88 44 148, 1080 4 5 36, prog 148500000Hz for '/dev/video0'
Jun 10 14:58:41 a8 appl: 5802004.02 VIDSRCCTRL-0 I: HDMI format accepted vidIo event - 1920x1080@60Hz
Jun 10 14:58:42 a8 appl: 5802004.50 RTP ERROR: find_by_index(sid=48) invalid index (session_counter = 52)
Jun 10 14:58:42 a8 appl: 5802005.14 VIDSRCCTRL-0 I: HDMI format change vpss msg - 1920x1080@60Hz
Jun 10 14:58:42 a8 appl: 5802005.14 VIDSRCCTRL-0 I: Send format change event from HDMI to requester - 1920x1080@60Hz
Jun 10 14:58:42 a8 appl: 5802005.14 VIDEOLC-0 I: Received SourceFormatEvent from video link 1 (1920x1080@60, digital, ok) in ready state
Jun 10 14:58:42 a8 appl: 5802005.35 MainEvents I: LayoutUpdated(p=1) outputNo=1 og=5
Jun 10 14:58:42 a8 appl: 5802005.35 MainEvents I: LayoutUpdated ...frame[1.1] wallpaper p=1 src=0 ig=184 x=0 y=0 w=10000 h=10000 l=1 b=0 clip
Jun 10 14:58:42 a8 appl: 5802005.35 MainEvents I: LayoutUpdated ...frame[GUI] gui p=1 src=0 ig=4 x=0 y=0 w=10000 h=10000 l=0 b=0 letterbox
Jun 10 14:58:42 a8 appl: 5802005.35 MainEvents I: LayoutUpdated ...frame[SelfviewPip] selfviewPip p=1 src=1 ig=2 x=7487 y=7499 w=2409 h=2409 l=5 b=1 snapBorder stretch
Jun 10 14:58:42 a8 appl: 5802005.35 MediaStreamController I: MV::getVCSetting getOutputPortStatus initialized 1
Jun 10 14:58:42 a8 appl: 5802005.35 MediaStreamController I: MV::getVCSetting localHwCookieHint_ 1 w 1920 h 1080
Jun 10 14:58:43 a8 appl: 5802005.51 RTP ERROR: find_by_index(sid=49) invalid index (session_counter = 52)
Jun 10 14:58:44 a8 appl: 5802006.65 RTP ERROR: find_by_index(sid=50) invalid index (session_counter = 52)
Jun 10 14:58:44 a8 vcodec: Power down ivahd 0
Jun 10 14:58:44 a8 vcodec: Power down ivahd 0: completed in 347 us
Jun 10 14:58:46 a8 appl: 5802008.69 RTP ERROR: find_by_index(sid=51) invalid index (session_counter = 52)
771
