Cisco SX20 web interface call control - input security pin
I have a Cisco SX20 and I would like to use web interface to dial to a conferece room (URI). However, the conference room requires security pin before I can see other participants. Is there any way I can enter the security pin through the web interface? The security pin can be easily entered from a remote control or a control panel, but it seems like the web interface can't accomodate such pin input.
Thank you
VIP Purple
There's no simple way to do it as you would from the remote or touch panel, but it is possible.
You can do it from the Web Interface through the Configuration > API page - You can type the appropriate xCommands in to the box at the bottom of the screen to get the unit to send the DTMF tones, ie
xCommand DTMFSend DTMFString:1234
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Thanks a lot
VIP Purple
You're welcome.  I hope that's going to work for you.
If your question is now answered, can you please mark it as so by clicking the correct answer button (see
https://supportforums.cisco.com/community/help#discussions_correct for how to do so).
Wayne
Wayne
779
