Cisco Telepresence EX90 remote is not working
Hi Experts,
I have a problem with EX90 is that when connecting the Remote Touch tablet to the screen ,it is not working at all. What could be possible the problem?
I beleive it's a matter of plug and play.
Appreciate your help.
Amr Sherif
Re: Cisco Telepresence EX90 remote is not working
Hello Amr Sherif,
What the version you run at this moment on the EX90 ?
Do you have power on the touch panel ?
From root can you ping the touch panel  ?
$ ping endeavour
PING endeavour.localnet (169.254.1.30) 56(84) bytes of data.
64 bytes from endeavour.localnet (169.254.1.30): icmp_seq=1 ttl=64 time=0.398 ms
64 bytes from endeavour.localnet (169.254.1.30): icmp_seq=2 ttl=64 time=0.400 ms
64 bytes from endeavour.localnet (169.254.1.30): icmp_seq=3 ttl=64 time=0.374 ms
64 bytes from endeavour.localnet (169.254.1.30): icmp_seq=4 ttl=64 time=0.412 ms
^C
--- endeavour.localnet ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3003ms
rtt min/avg/max/mdev = 0.374/0.396/0.412/0.013 ms
And also check the file messages.log under directory /var/log
[tandberg:/var/log] $ pwd
/var/log
[tandberg:/var/log] $ grep -i endeavour messages.log
Mar 19 12:47:13 (none) xinetd[1716]: Reading included configuration file: /etc/xinetd.d/endeavour-dl [file=/sbin/../etc/xinetd.conf] [line=48]
Mar 19 12:47:13 (none) xinetd[1716]: Reading included configuration file: /etc/xinetd.d/endeavour-upgrade [file=/etc/xinetd.d/endeavour-upgrade] [line=13]
Mar 19 12:47:17 (none) xinetd[1716]: Reading included configuration file: /etc/xinetd.d/endeavour-dl [file=/sbin/../etc/xinetd.conf] [line=48]
Mar 19 12:47:17 (none) xinetd[1716]: Reading included configuration file: /etc/xinetd.d/endeavour-upgrade [file=/etc/xinetd.d/endeavour-upgrade] [line=13]
Mar 19 12:47:17 (none) xinetd[1716]: readjusting service endeavour-dl
Mar 19 12:47:17 (none) xinetd[1716]: readjusting service endeavour-poke
To see what the touch panel report on error message.
/Hans
We have a similiar problem. Sometimes the touch panel is working sometimes it is not working. It gives the error on it "the touch screen has no network conneciton tandberg". What do you think is the problem?
Hans, you asked the version of the EX90? Is there any requirement about the version?
Best regards,
Tufan
Hello Tufan,
Just want to understand which version you run during this time on the EX90 . And also looking if you can capture the logs explained on April 10th 2012, to review for which reason it occur.
One CDETS open for  :  CSCtw86018    Touch Control Device freezes and becomes unusable [Happen after upgrade]. But in your case it occur random to stop working , and you need to reboot the EX90 ?
What you also can do is run the tcpdump command :
$ tcpdump -i eth1.4090 -vv -X
/Hans
1056
