Cisco TelePresence SX20 with Laptop
I am using a Cisco TelePresence SX20 as standalone endpoint configured with Public IP address (in Pakistan). I want to connect a laptop (in Canada) to start video conferencing using laptop camera. Please advice me the software to install on the laptop so that i can start the video conference with my SX20 based on IP configured on my SX20.
For understanding kindly refer to the attached network layout.
Please help me its urgent.
1 ACCEPTED SOLUTION
Hi,www.ciscojabbervideo.combr
br Oleksandr
br Oleksandr
br Oleksandr
br Oleksandr
VIP Purple
In addition to what Oleksandr
In addition to what Oleksandr has recommened.  If you use the Jabber Video client you'll need to dial your SX20 address using the following format.
<something>@<SX20_IP_Address>
<something> can be whatever you like, it's just a placeholder, because the Jabber Video client can only dial URI formatted addresses, they can't dial just a straight IP address.
 Could you please tell me the
Could you please tell me the third party software in place of Jabber from where i only put the ip address of SX20 and start the video conferencing.
Option 1 --- Use SX20 to dial
Option 1 --- Use SX20 to dial the Jabber (dial the SIP address of the Jabber);
Option 2 --- Use the Jabber to dial SIP address of SX20, which is XXXXX@IP address of SX20.
If you have infrastructure support, you can use Jabber to dial IP Gateway address, then followed by Conference ID and security PIN, but this is not for your case.
 Hi, Thanks for the support.
Thanks for the support. We test the jabber video in Pakistan and its is working fine when we call from the Cisco SX20 to jabber SIP URI. But once we try to connect our customer in Canada the video is coming but no voice is receiving on both ends.
Note: When dial from jabber to SX20 (e.g test@xx.xx.xx.xx) IP the call connect but message POP up saying "No Incoming Video".
Kindly help me what could be the issue.
710
