but due to unknown circumstances you might need to use 3rd part digital video recoders
Remember when you use DVRs you can capture far-end voice & video + near-end video (from splitting the HDMI cable) but this does not include near-end voice. Workaround would be to use other microphones connected directly to the DVR.
You may try the following site for external recoders.
IntroductionCUCM Routing RulesDial String implementation PolicyCUCM Routing LogicSIP URI Call Routing Analysis+++ Case Study: 1 ++++++ Case Study: 2 +++Conclusion
Introduction
Over the last few months, I have had the privilege of working on SI...
view more
Hi All,
Are you getting this error “Installer User Interface Mode Not Supported. The installer cannot run in this UI mode. To specify the interface mode, use the -i command-line option, followed by the UI mode identifier. The value UI mode identifiers...
view more
