Cisco TMS - custom command issue with MXP endpoint
samy lemeunier
Hi all,
I try to disable the H264 RCDO protocol with the TMS on custom command on all the endpoints (for resolve one issue with lync2013 client)
It work for the C-SERIES EndPoint but doesn't work for the MXP EndPoint.
I have try with this command:
<configuration><conference><set configuration="H264RCDO:off"></set></conference></configuration>
Do you have ever met this issue ?
DO you know a solution?
Thanks by advance
Samy
Patrick Pettit
What version of TMS are you currently running?
I have TMS 14.3.1, and if you search in the configuration templates in TMS under MXP you should see the configuration item to turn this off for you.
Anyhow...
<Configuration><Conference><H264RCDO>Off</H264RCDO></Conference></Configuration>
May be easier to use the configuration in TMS, but the above string should work.
Hope this helps.
VR
Patrick
Patrick Pettit
Anyhow...
Hope this helps.
VR
Patrick
Hi Papettit,
Thanks for your answer!
I try and it works !
 I think I got confused with XML for CSERIES...
Thanks!
Have a nice day.
Samy
