09-17-2017 01:52 AM - edited 03-18-2019 01:28 PM
Hi all
In CMS configuration guide, it is said that at least 3 nodes should be configured in database cluster and xmpp cluster in order to archieve full resilliency. However, one of my client has two CMS 1000 servers. Is it possible that I create the third CMS VM on a BE7K and configure ONLY the database clustering and XMPP clustering on it, so that makes 3 nodes to form the database cluster and XMPP cluster?
Thanks!!
Danny
Solved! Go to Solution.
09-17-2017 02:32 PM
09-17-2017 02:32 PM
09-17-2017 07:53 PM
Thanks patrick.
Can I cluster only callbridges and databases and leave xmpp servers standalone? Since my client only purchased two CMS 1000. What will happen if I leave xmpp servers standalone except no resilliency
09-17-2017 08:00 PM
You can do that, that is how I have my CMS cluster setup currently. I don't know of all the scenarios of running multiple Meeting Servers with their own standalone XMPP servers, but I do know that if you don't have XMPP resiliency setup and each CMS has a CMA client logged in, that they won't be able to message each other as XMPP isn't linked.
01-08-2018 04:48 AM
Hi Patrick,
My customer purchased 2 x CMS1000 in order to have a full redundant Solution (The BOM was suggested by Cisco Presales PDI)
After reading many deployment guides : (single combined, single split and resilient deployment guide) i am still confused on the ideal architecture for the customer.
I can manage to have an additional VM to install a third DB since we need to have at least 3 DB for redundancy.
On the other hand i have some questions:
1) Is this a correct deployment?
* First CMS 1000 (Combined server) : All services : CallBridge, XMPP, DB, Webadmin, Webbridge, Turn.
* Second CMS1000 (Combined Server) : All services except XMPP (Because i have only 2 callbridge licenses and Xmpp needs a Callbridge . the docs says that it's better to have 1 XMPP than 2 active)
* A separate VM : DB and Recorder
2) In this type of deployment , do i need a loadbalancer? Following the guides the loadbalancer is only configured in a split server deployment
2) The scalable and resilient deployment guide is not clear about how to setup The edge components (Turn, Webbridge ) . Mostly questions about interfaces and how to place them in the DMZ in the same server. Can you give me some examples please?
Thank you in advance
01-08-2018 05:12 AM
Hello. The XMPP follow the same concept as DB, for redundancy use 3 (do not use 2, unsupported).
For callbridge redundancy it is mandatory to have DB redudancy, so, you need to deploy 3 DB servers as you described.
If you have only one XMPP and this server fails, your CMA clients will not be able to sign In (but other devices will be able to connected to the second CB)
You can use Single Server combined, but keep in mind that your "a" interface will be your local network (where webadmin will run together with SSH deamon) and another interface (b or c depending on your scenario) as Public.
PS: You license file will be associated to tha "a" MAC address.
1) in my point of view is a valid concept (take into account its characteristics)
2) You don´t need loadbalancer in case you want external CMS registration and configure your XMPP to listen on a public interface (LB is basically an extension of XMPP)
3) configure both (WB and Turn) with Public IP interface (b or c, depending on your scenario) and check the Deployment Guide regarding the required connections. You will need to use APIs to configure this environment and play with certificate bundles for trust relationship. Special attention to Turn TLS. Remember to match DNS SRV Records with CN
Hope it helps. Best Regards
01-08-2018 06:09 AM
Elter,
Where does it talk using (3) servers for DB redundancy and XMPP redundancy and (2) not being supported? I have been through the old Acano training and the new Cisco training and this was never relayed via the training's at least.
01-08-2018 06:34 AM - edited 01-08-2018 06:37 AM
Former ACE I, didn´t explicitly metion, but if you realize the environment use 3 DB servers.
COLLAB350 day2 instructs you that you are required with at least 3 servers for DB redundancy (odd number, 3 or 5)
Deployment Guide says:
Note: Do not create a database cluster of 2 nodes, as it reduces resilience rather than increases
it. Using an odd number of nodes aids resiliency in the case of network partitions, and Cisco
recommends running at least 3 database nodes.
So, if you deploy a resilient solution and expect a resilient solution, you need to use 3 DB servers. In case you call TAC with 2 DB servers only they may instruct you that your scenario do not provide redundancy.
PS: "not supported" doesn´t mean it will not work.
02-02-2018 03:47 PM - edited 02-02-2018 03:48 PM
Database Clustering and subsequent elections for DB Master require a quorum to properly elect the Master.
If you have an even number (4) of DB's in a cluster you run the risk of having two DB's separated from the other 2 DB's and each set of two could then enter into a Master election resulting in a dual master scenario.
01-09-2018 04:41 PM
03-14-2018 04:29 AM
Hi guys,
Finally i was able to get an additional CMS license from our local Cisco AM.
Now my design will be as follow:
1) 1 X CMS 1000 core (Callbridge1,XMPP,1Database1)
2) 1 x CMS 1000 edge (Webbridge1, Loadbalancer1, TURN1)
3) 1 VM CMS core (Call bridge2 XMPP2, Database2)
4) 1 VM CMS core (Call bridge3 XMPP3, Database3)
5) 1 VM CMS edge (Webbridge2, Loadbalancer2, TURN2)
I think with this design i have full resiliency for all components.
Now i am configuring DNS records but i have some questions:
My DNS configuration will be as follow:
Type |
Hostname |
DNS INTERNAL/EXTERNAL |
Resolve to |
A |
cms-core1.example.com |
INTERNAL |
10.12.40.58(LAN) |
A |
cms-core2.example.com |
INTERNAL |
10.12.40.158(LAN) |
A |
cms-core3.example.com |
INTERNAL |
10.12.40.59(LAN) |
A |
cms-edge1.example.com |
INTERNAL |
10.12.230.58(DMZ) |
A |
cms-edge2.example.com |
INTERNAL |
10.12.230.158(DMZ) |
SRV |
_xmpp-server._tcp port 5269 Priority 0 weight 10 |
INTERNAL |
SRV |
_xmpp-server._tcp port 5269 Priority 10 weight 10 |
INTERNAL |
SRV |
_xmpp-server._tcp port 5269 Priority 20 weight 10 |
INTERNAL |
SRV |
_xmpp-client._tcp port 5222 Priority 0 weight 10 |
INTERNAL |
SRV |
_xmpp-client._tcp port 5222 Priority 10 weight 10 |
INTERNAL |
SRV |
_xmpp-client._tcp port 5222 Priority 20 weight 10 |
INTERNAL |
A |
cms-join.example.com |
INTERNAL |
10.12.230.58 (DMZ) |
A |
INTERNAL |
A |
loadb1.example.com |
EXTERNAL |
Adresse IP Publique CMS edge 1 |
A |
loadb2.example.com |
EXTERNAL |
Adresse IP Publique CMS edge 2 |
SRV |
EXTERNAL |
SRV |
EXTERNAL |
SRV |
EXTERNAL |
SRV |
EXTERNAL |
A |
EXTERNAL |
Public IP Address CMS edge 1 |
A |
EXTERNAL |
Public IP Address CMS edge 2 |
Is this DNS config correct?
Do i need to configure A records on internal and external DNS for cms join webrtc?
In my case, with 2 edge servers, do i need 2 A records pointing to both servers?
In case of one of the edge servers is down, the DNS will automatically resolve to the second edge?
03-14-2018 05:26 AM
Be careful with SRVs. To have load balance you must use the same priority. If the servers do not have the same HW capacity, you can use the SRV weight field for the DNS load sharing.
Take a look here: https://en.wikipedia.org/wiki/SRV_record
_xmpp-server._tcp port 5269 is used for federation. If you do not have it internally, you don´t need this one at your internal DNS.
Your cms-join.example.com record will point to the Public webbridge IP on External DNS and is OK if you network allow the connectivity from your LAN to DMZ to point the cms-join.example.com record on iternal DNS server to your Edge (the webbridge will need to listen on both interfaces, DMZ and Public). Another method is to configure the webbridge component at your core server and keep the traffic internally. Using APIs you can configure multiple webbridges.
R: Yes, but it depends on your topology
R: Yes. You will have DNS round robin characteristic
R: When you have two DNS A records, both are informed and the DNS server may change the order randomly. The initiator will contact the first one and in case it is not reachable it will try the second one (but here it is the behavior of the session initiator). You may also decrease the TTL to speed up the order changes.
Hope it helps
03-14-2018 05:51 AM
Thank you very much Elter,
Great answer !!!
Just a detail: for edge servers i am planning to setup just one interface on DMZ and do NAT to external public IP.
10-09-2017 10:44 AM
Yes, but keep only one XMPP enabled and in case you have CMS Edge, the trunks will need to be configured at the XMPP server only.
03-19-2018 05:56 AM
Hello Experts,
I have some queries regarding CMS clustering. One of my customer purchased one CMS 1000 appliance and for redundancy they want to deploy second CMS on Hyper-V. So can we cluster two call bridge, XMPP and webbridge just using one database. and Do we required extra licenses to activate second call bridge, web bridge and XMPP service on second CMS.
Here we are considering single deployment.
Thank you..
