12-01-2017 12:17 PM - edited 03-18-2019 01:40 PM
Any help from expert !
I have a 3 VM server setup for xmpp , and trying to setup the xmpp clustering, I did followed the clustering commands from the scalable and resilience deploying document ,, every time I did ( 5 times ) the call bridge secret won't match in live.json file ,,,
the database and callbridges clustering is good and working , except the xmpp clustering.
show xmpp cluster status show 3 server , one being the leader ,other as followers , but the console syslog messages throw ,,tcp failures , xmpp server not connected or failed error.
I don't see any certificates error so far ,,,
using the notepad to copy the callbridge name and secret , thru secureCRT , there is no chance of spaces being copied,,, the xmpp callbridge list and secret is the same across the 3 xmpp servers.
as per the TAC ,, the callbridges secret under xmpp in live.json file should MATCH ,,for successful xmpp clustering ...
anybody have any inputs as to why there is NO match ,,,iam using version 2.2.8.
Solved! Go to Solution.
12-17-2017 01:34 AM
12-01-2017 10:39 PM
12-02-2017 03:44 AM
Yes, indeed we did restart the whole cms servers , and also we did RESET the two xmpp server ,except the first xmpp one ,,,and i did it with TAC engineer ,,he suggested to go for reboot.
xmpp callbridge list across the 3 xmpp and its secret is same ,,
xmpp cluster status says ,,,leader and followers ..
but the issue with secret MATCH in live.json file ,,,i don't know why it is not matching,,,the whole string is alphanumeric characters...
12-03-2017 07:21 AM
just to update the question!
xmpp cluster trust 3CBcerts.CRT
xmpp cluster trust 3XmPPCerts.crt .... which security bundle certificate to use..
3CBcerts.CRT contains ALL the 3 call bridge security certificate , likewise 3XmPPCerts.CRT contains ALL the 3 XMPP security certificate ...
12-08-2017 02:58 AM
12-17-2017 01:34 AM
