Codec C40 Access to Cisco Telepresence Maintenance Shell Mode
When accessing the codec C40 via the command line interface (telnet or ssh) as admin user, it accesses on maintenance mode by Cisco Telepresence Maintenance Mode as the attached file so i need to solve this issue.please advice
VIP Green
There's a good document on
There's a good document on the Maintenance Mode in the Documents Section of the forums.
Give some of the options there a shot ("selectsw" is a good one to try), or enabling the "root" login and upgrading/reinstalling the codec software via WinSCP (instructions for this can also be found in the Documents section: Upgrade using WinSCP).
Wayne
Please remember to rate reponses and to mark your question as answered if appropriate.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Hello WayneThanks for your
Hello Wayne
Thanks for your support and i will do it but i havn't any image to upgarde it so please send me an URL to download it or could i must use my cisco service contract nubmer to download it?
sure, once upgraded operation done i will rate your response ....i don't forget that
VIP Green
If you have an active service
If you have an active service contract, you can download the firmware from the Download Software part of the Cisco web site.
If you are downloading a different major release from what you have (ie, if you have TC5.x and want TC6.x, or TC7.x, you will also need to obtain a new release key from the Cisco Licencing Portal.
Wayne
Wayne
Hello WayneThere isn't
Hello Wayne
There isn't systemtools rootsettings on command on Maintenance Mode Shell as the attached file to enable root mode to access C40 through WinSP Tool so please advice
VIP Green
As per your screenshot, there
As per your screenshot, there is a "rootsettings" command.  You should be able to use this to enable the "root" login.
Wayne
Wayne
296
