Codec C40 - Remote Control / Touch Controller [Either One]
Hi all TP Experts,
I just bought a C40 and just set up that. I have the "Remote Control" and the "Touch Controller", that are set up normally and can
uniquely operate.
But that cannot operate together, that mean I connected the "Remote Controller", then the "Touch Controller" cannot use and I connected the "Touch Controller", then the "Remote Controller" cannot use.
Is it I only can use the either one control?
1 ACCEPTED SOLUTION
Bronze
Hi CHi Fai,
yes, you can use only one device at the time.
Best regards, Ahmad
Bronze
Hi CHi Fai,
Best regards, Ahmad
Thanks for your reply!
Is it possible to set use that together?
Hi Chi Fai,
This is not possible...
Bronze
Hi Chi Fai,
I was away for a while but I see Ashwani already provided with the answer and I just want to reiterate his answer, only one device at the time.
best regards, Ahmad
236
