Compositing in Multisite Calls
A customer is planning to buy some C60 and MX200 systems. They want us to provide them some layouts for the C60s to be sold. They sent us a template which I attached in this discussion. And I created a layout xml file using TC console (also attached it in this dıscussion) named test_layouts. And I uploaded the layouts to a C60. Now I am testing and I have some problems.
In test environment I have a C60, a C20 and a E20. Anyway the cases in the test are like below:
- Before I uploaded the layouts I created, there was no problem. I can make point to point and multisite calls without any problem.
- After I uploaded the layouts I have no problem in point to point calls. It works. I can change layouts as expected. But when I try to make a multisite conference between three systems, I have problems. I can not see video from third endpoint and I can not send video to it neither. I tried a lot of thing (resetting and re-uploading layouts, factory reset on C60 etc...) but it didn't work. Is there anyone who tried that?
You can find the layouts and the template attached.
Best regards,
Tufan
Isn't there someone who tried this before?
Best regards,,
Tufan
Silver
Hi Tufan,
I believe you have a TAC case open for this. We came through this case and we are working to get this resolved. The engineer Chetna would be working with you tomorrow. I will also be available during her shift hours. We would appreciate if you can come on a webex session and we will help you resolve the issue.
Mubashshir Akhtar
Thanks Mubashshir Akhtar
346
