Configure my VCSc with VCSe on Public IP
Hi Guys,
I have a VCS control sitting under my company's Private IP and I have my Customer's VCSe on Public IP.
Will it be possible to configure my VCSc with the VCSe after configuring Traversal Zones ?
What ports needs to be open by my firewall team in this scenario ?
Any other thing which I need to keep in Mind.
FYI, this is only for testing purpose.
Will Appreciate any response.
Saurabh
1 ACCEPTED SOLUTION
Re: Configure my VCSc with VCSe on Public IP
> So, Practically there are no as such risk involved and my Customer can use Public IP on VCSe
> without going for Dual Network Option Key. ( which is used to make VCSe more secure).
Cisco highly recommend VCS-E deploy under DMZ however it also true many customer does deploy VCS-E on public network directly.
Please refer https://supportforums.cisco.com/thread/2154738?tstart=150 for additional VCS security information.
Next VCS software release, X7.2, plan to be supported build-in basic firewall feature what allow to configuring allow/deny list base on IP address/Port(s)/Protocol which should help to improve security level even VCS-E deployment on public network directly.
> So, Shall I ask my Customer to just buy a Public IP , thats it and we are good to go?
One public IP will require on VCS Expressway, VCS Control can be use shard NAT address (i.e share internet access from office network).
Also you will need SRV DNS management (if small deployment probably best to use external DNS service, there are many company provide DNS hosting service both as charged service and as free service).
Yes, it does support VCS-C and VCS-E traversal link even those VCS located in separate location.
Please download latest VCS-C and VCS-E deployment guide from,
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_Basic_Configuration_Cisco_VCS_Control_with_Cisco_VCS_Expressway_Deployment_Guide_X7-1.pdf
Appendix 1 should provide sample configuration for both VCS-C and VCS-E.
Appendix 3 should provide ports information that should allow by firewall for traversal link.
Also the document “VCS IP port usage for firewall traversal” may become handy to understand port requirement in both direction. This document is available from,
http://www.cisco.com/en/US/docs/telepresence/infrastructure/vcs/config_guide/Cisco_VCS_IP_Port_Usage_for_Firewall_Traversal_Deployment_Guide_X4_to_X7.pdf
So, in a way different companies can use 1 VCSexpressway located in a remote location and on Public IP?
Is there any risk involved in it?
And for accomplishing it, we have two create different Traversal Zones for linking different VCSc with one VCSe?
Saurabh
Also, since there is no Physical Layer 1 connection between VCSc and VCSe ? How will routing of packets , call signalling and end to end data will flow?
Do you mean, that Traversal Zone will accomplish it after I am done with Traversal zone setup?
Saurabh
VCS support multiple SIP/H323 domains and also you able to create subzone per such domain to manage registration separately.
SRV DNS will help have multiple domains but pointing to same VCS E which has a single public IP address.
If search rules doesn't manage properly, possibly other company may failing to different company infrastructure resource (i.e. using other company MCU resource) or calling to other company Endpoint.
From next VCS software release version, X7.2, you may configure subzone level for calling source on search rule which will help this challenge.
You will need to create traversal zone per VCS-C and VCS-E link (if cluster, you able to add all cluster VCS information in same traversal zone configuration).
So for example, assume you nave VCS-C1 and VCS-C2 and shared VCS-E, then you will need to create following traversal zone.
1) traversal client zone on VCS-C1 pointing to VCS-E
2) traversal clinet zone on VCS-C2 pointing to VCS-E
3) traversal server zone on VCS-E for VCS-C1
4) traversal server zone on VCS-E for VCS-C2
Also you will need search rule on each VCS.
VCS-C and VCS-E will keep one signal link alive once traversal link establish.
VCS-E will communicate VCS-C using this link (i.e. when VCS-E receive incoming call, VCS-E inform VCS-C to make out-going call to establish firewall traversal call).
Yes, traversal management link will remain alive once traversal zone configure and establish the link.
Port information is available on guide I mention in earlier reply.
Thanks Tomo for the reply.
So, Practically there are no as such risk involved and my Customer can use Public IP on VCSe without going for Dual Network Option Key. ( which is used to make VCSe more secure).
Saurabh
Thanks Tomo for replying every time ....
Appreciate your response.
Saurabh
1051
