connect sx20 with polycom endpoint
Hi guys
I would like to know if there is special requirements to connect quick set sx20 Cisco with other brands telepresence for instance Polycom, Lifesize, Sony.... Customer has 3 sites and now want to replace one with sx20
I'm not good at technical issues
Tks a lot
Everyone's tags (1)
1 ACCEPTED SOLUTION
Community Member
you may need the Multisite
you may need the Multisite license for conferencing  , you may also need a Public Static IP depends on who will make the call.
other than that just configure the H323 section in the configuration tap and you are set to go.
1 REPLY
Community Member
88
