Connecting PrecisionHD 1080p 12X to 3000 MXP codec
Has anyone tried that?
Unfortunately I do not have the necessary equipment to test it so any help would be appreciated.
Everyone's tags (5)
Hi maciej
For MXP you must use PrecisionHD Camera, 720p (CTS-PHD=).
MXP3000 dont has HDMI-in
Br. Oleksandr
br Oleksandr
Yes, I'm aware of that but if you use an adapter?
You may connect 1080p12X PHD camera to 3000MXP via DVI in-put interface by using HDMI-DVI cable (or adapter), but not support full frame rate like 720pPHD camera via camera port.
You need to set video output  to 720p using dipswitch of camera .
Kind regards,
Dharmmesh
Thanks for the answer. If I use the DVI-in I won't be able to connect a PC, right?
And what about camera contorl, no problems with that?
648
