Showing results forĀ
Search instead forĀ
Did you mean:Ā
Could I move ISDN License between Tandberg Edge95 MXP?
mustika.wiguna
Dear Community,
Currently we have a broken Tandberg Edge-95 MXP with ISDN license on it
We plan to change  the broken Tandberg Edge-95 MXP to another spare Edge-95 MXP. Unfortunately, our spare do not have ISDN feature license on it
Is it possible to move the ISDN License between Tandberg Edge-95 MXP devices?
Please suggest.
Thank you in advance for any help you can provide.
Cheers,
Ketut Mustika Wiguna
Dharmesh Nandoria
Hi Ketut,
It is not possible to swap license between unit w/o RMA , I will suggest to open TAC case/ RMA for faulty device . You will get replacement device with same licenses.
Kind regards,
Dharmmesh
URL for transfering the Licensing
https://tools.cisco.com/SWIFT/Licensing/PrivateRegistrationServlet
Click " Register for an RMA License"
HTH, please rate.
Manish
crisalex
I think the licensing team will be able to help out
The contact is : licensing@cisco.com
Good luck
