02-12-2014 07:28 PM - edited 03-18-2019 02:35 AM
Dear all,
My client would like to know the distance coverage of the C40 default Onmidirectional microphone?
Anyone can help ?
Best Regards,
Ben Lai
Solved! Go to Solution.
02-13-2014 03:30 AM
Hi Ben,
The Omni Directional Microphone used on the codec isan Audio Technica AT841UG.
You can refer to the following link for details and specifications-
http://eu.audio-technica.com/en/products/product.asp?catID=2&subID=7&prodID=1469
02-13-2014 04:54 PM
Hi Ben,
As a general rule for our users, we tell them to be within 2m of the microphone.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
02-14-2014 02:30 AM
In field, the MIC can capture up to 7m radius of a person talking regularly. You need to check your device input level when in place (you can add gain in the codec).
The problem could be a background noise or different audio sources position
(ex.: a rectangle table and the MIC in the center will capture stronger sound from participants closer to the MIC).
In large rectangle tables you can use the 2m rule that Wayne mentioned (use more than one MIC if needed).
Hope it helps.
02-13-2014 03:30 AM
Hi Ben,
02-13-2014 04:54 PM
Hi Ben,
Wayne
07-21-2014 07:23 AM
Dear Wayne,
would you mind explaining the term " within 2m of the microphone"? It is talking about diameter or radius?
Best Regards,
Benjamin
07-21-2014 04:40 PM
Hi Ben,
Our suggestion was the user should be no further than 2m away from the microphone - so, it'd be radius.
Wayne
02-14-2014 02:30 AM
Hope it helps.
