CTMS Qos setting not saved !
Marwan ALshawi
hi
i have CTMS v1.6.0.0-108 when i change the Qos to setting to i want,  it go back to AF11 for both TP and CUVC after i hit apply !!
is this a bug,, is there any workaround !!
gogasca
Level 10
Level 10
I have that version in my lab and works fine
Im using IE 7.0
happens the same from all machines or just your machine?
Which browser ur r using?
just FYI
after a server restart fixed why no idea
but the other option i was thinking about if it wouldn't work just upgrade to 1.6.2 or .3
thank you
