CTS-MAN integration with LDAP/Exchange
Hi guys
just wanted to confirm if its ok to have the LDAP user account and the tpsuper user ( the CTM user who has full access on all the TP rooms mailboxes) the same user with the following privileges in the domain
member of  Domain Admin Group, Enterprise Admin Group and the MS Exchange Servers ?
or it must be diffrent user accounts ?
i did try it with prequalification tool and all the results was successful but i am not sure if their is any technical requirements behind it or not
Thank you
Green
Re: CTS-MAN integration with LDAP/Exchange
as long as it has full access to those rooms is ok, in Exchange by default Domains admin inherit no read access and no sent as for users
but if prequal took is ok you should be good
let us know
you can confirm by logging into the room calendar using ctm account via OWA
thanks for your answer, just to let you know
one user account can work for both LDAP and exchange
the user for LDAP only need to be member of domain users group
for exchange has to have full access or read on all of the TP room accounts
tried it with pre-qual tool worked fine and a colleague who done it in production confirmed it to me
by the way why you need send as ?
Thank you
You don't need send as/receive as rights on the account that CTS-Man uses for authentication to Exchange; as stated, it only needs to be a member of the Domain users group.  We have seen customers add this account to the domain admins group, which does use implicit denies to the mailstore, such as send as/receive as, so it's simply something to be mindful of.  As stated, as long as the account is a member of the Domain Users group, and is granted either read only or full access rights to the room mailboxes, all should work as expected.
That helped.
CTS-Man unfortunately is a pain as Unity VM system is when dealing with MS products
823
