CTS Manager & Multipoint connectivity with CA Spectrum Management Software through SNMP v2
I am configuring CTS Manager & Multipoint to interface with CA Spectrum management software through SNMP v2, the administrator of the CA Spectrun Software is asking for the MIBs & OID. From where I can get the MIBs & OIDs and which MIBs & OIDs I should send to CA Spectrum Management software administrator to work it properly with CTS Manager & Multipoint. CTS Manager & Multipoint are running software ver 1.6.
Re: CTS Manager & Multipoint connectivity with CA Spectrum Manag
MIB information for the CTM and CTMS products can be found at the following locations:
CTS Manager:
http://www.cisco.com/en/US/partner/docs/telepresence/cts_manager/1_6/admin/ctm1_6adminguide.html
Chapter: Supported MIBs for Cisco TelePresence Manager
CTMS:
http://www.cisco.com/en/US/partner/docs/telepresence/multipoint_switch/1_6/admin/CTMS_Release1_6.html
Chapter: Configuring CTMS Administration Software.
Half Way down the document below table 4-6 on SNMP Settings, It lists the FTP server where MIB support is listed.
Let us know if this does not provide what you need.
Wayne D.
And what are MIBs & OIDs required for CTS 3000 System.
Green
ftp://ftp-sj.cisco.com/pub/mibs/supportlists/cts/cts-supportlist.html
For OID you can use any snmp translator once you install the MIB
725
