CUBE & VCS Integration
Hi Guys,
I am having issue on integrate CUBE & VCS.
In VCS, I created a neighbor zone to the CUBE w Infrastructure Device.
Managed to see the SIP and H323 connections is up.
EP1 to VCS-E to CUBE to EP2
Both way cannot call.
EP1 to EP2's error is Request Timeout in VCS-E
EP2 to EP1. Call drop.
It will be good if you have any configuration so that I can refer.
Thanks.
1 REPLY
Re: CUBE & VCS Integration
3 questions.
1) what is the purpose of this configuration? What are you trying to accomplish?
2) What protocol(s) are you using when the calls are made?
3) Can you post your CUBE config and tell us how the VCS and end points are configured?
336
