Community Member
CUCM 8.6.2 and ISDN GW 3241
Dear all,
I have CUCM 8.6.2 and ISDN GW 3241.
3 codecs: C60 and 2 x MX20 are registred to CUCM.
CUCM is registred with 3241 over H323.
Incomming and Outgoing Audio calls works ... but no Video.
From what I see on 3241 gw information problem is that CUCM don't send it's capabilities to GW (video):
Started at: 16:07
Call progress:
Connected
- IP call from "xxxxx2901" with IP x.x.x.x which called "xxxxxxx908", Connected to ISDN destination "xxxxxx908"
Participant details:
  • Unique index: 19
  • Name: "SOME NAME"
  • E.164: "xxxxx2901"
  • Call type: H.323 (IP - x.x.x.x)
  • FECC: Not established
  • Progress: connected
  • Negotiated received video bandwidth: 0.0 kbps
  • Measured received video bandwidth: 0.0 kbps
  • Unique index: 20
  • Name: "<unknown>"
  • E.164: "xxxxx908"
  • Call type: H.320 (ISDN)
  • FECC: Established
  • Channel bonding map: 5 channels in use -  1 2 3 4 5
  • Channel rate: rx=64kbps;  tx=64kbps
  • Negotiated received video bandwidth: 1761.2 kbps
  • Measured received video bandwidth: 30.4 kbps
Where should I look for problem?
Many thanks,
Lukasz
Everyone's tags (6)
Community Member
Did you get a soution for the above scenario ?
I have a similar setup for a client with Call Manager 9.1 and i want to know wheter ISDN calling will work or not ?
Community Member
Yes - received ISDN GW 3241 firmware that support SIP (previous was only supporting H323).
Now you can get this soft from cisco support page.
808
