dialing from EX60 Favorites not working
I'm using an EX60 attempting to dial a h323 device. If I dial from the dialpad H323:<IP address> it connectes fine. When I save this number in the favorites and dial by pressing the favorite it says unknown address could not place call...
On the favorites webpage it does allow me to select sip/h323 but this doesn't work eather.
How can I save ip address numbers to the favorites.?
Looks like I can answer my own question. If I enter the number in the favorites H323@ it will work from the favorites fine. Case sensitive as well.
Silver
Hi Scheived
could you check what is default protocol set to under conferenc 1 setting ?
Default is SIP
Silver
please change it to H323 as you are making direct IP calls.
then try and check
No, most of the calls are sip so I want that to remain the default.
253
