Community Member
Diferences between higdefinition and premiumresolution
What'ss the diference between high definition and premium resolution option key in sx20?
Thanks in advance.
Re: Diferences between higdefinition and premiumresolution
$3465     :-)
br Oleksandr
Silver
Hi ,
Probably Oleksandr have given you teh actual difference of amount that will be slipped out from your budget
here is the technical detail just in case you were looking for
HD
  • High Definition (HD) w720p 1280x720 30 fps
PR
  • High Definition (HD) w720p 1280x720 60 fps
  • High Definition (HD) w1080p 1920x1080 30, 60 fps
regards
Ravi kr
If you have purchased PR key then you do not require HD key for codec .
*s SystemUnit Software OptionKeys NaturalPresenter: "true"
*s SystemUnit Software OptionKeys MultiSite: "true"
*s SystemUnit Software OptionKeys PremiumResolution: "true"
*s SystemUnit Software OptionKeys HighDefinition: "false"
*s SystemUnit Software OptionKeys DualDisplay: "true"
Kind regards,
Dharmmesh
457
