DNS issues TC5.1.x
Tried to search for it in the Bug Toolkit and in the Forum, but did not find anything related.
I have an endpoint (c40, TC5.1.4) where DNS does not work. Its set up to use static ip and 2 static dns servers, as well as with the default gw.
The firewall guy told me he did not see any port 53 requests and I looked at a tcpdump on the endpoint
and can also confirm that. Interesting enough dns requests go from 127.0.0.1 to 127.0.0.1 port 53,
but not to the external defined ones.
I tried to remove the DNS and re-added them again, no change.
I noticed that the /etc/resolv.conf does not show any entries. (also a ping to a hostname fails).
Anyone stumbled across such an issue and has a tip?
Next step would be to do a factory default reset, but this would also kill the network connection, so I would need somebody on site.
Everyone's tags (5)
1 ACCEPTED SOLUTION
DNS issues TC5.1.x
I am not sure what went wrong in the 1st place when one needs to manually go in an edit the files. I wonder whether the changes will survive a reboot of your system. When rebooting the filesystem and configs are created anew. If your reboot the system all remains working, I would say you are in good shape. If not, need to check the logfiles what went wrong where.
DNS issues TC5.1.x
the script which configures DNS is S17resolvconf located at /etc/init.d :
[dderidde-ex90-home:/etc/init.d] $ ls S17resolvconf
S17resolvconf
It consults a few files to create the DNS environment. E.g. :
/config/sysconfig/network
/config/sysconfig/ipstack
/config/sysconfig/dns
/etc/resolv.conf.d/resolv4.conf
My /etc/resolv.conf file looks like this :
[dderidde-ex90-home:/etc/init.d] $ cat /etc/resolv.conf
# Generated by configupdater
nameserver 10.48.160.30
Can you check the files mentioned above and check their contents to see "what's there" ?
You can also look for any errors in the logfiles. E.g. :
cat /var/log/console | grep resolv
Do you have remote access to the device via a public address?
Danny.
DNS issues TC5.1.x
Yes, I can reach it. I now manually edited the
[ep:/etc/init.d] $ cat /config/sysconfig/network
# This file is generated from parameters at
# Tue Aug 21 17:28:15 UTC 2012
METHOD=Static
IPSTACK="IPv4"
IPADDR=""
SUBNET="255.255.255.248"
GATEWAY=""
[ep:/etc/init.d] $ cat /config/sysconfig/ipstack
cat: /config/sysconfig/ipstack: No such file or directory
[ep:/etc/init.d] $ cat /config/sysconfig/dns
# Tue Aug 21 17:28:19 UTC 2012
DNSDOMAIN=""
NS1=#. .
NS2=
NS3=
NS4=
[ep:/etc/init.d] $ cat /etc/resolv.conf.d/resolv4.conf
# Generated by S17resolvconf
/config/sysconfig/dns file and added the settings and restarted
S17resolvconf which then created the resolf.conf file with the right content.
The endpoints seems to register fine now.
Is the endpoint now a "sane state" or is there something else I should do / fix?
DNS issues TC5.1.x
Re: DNS issues TC5.1.x
To see if it would be ok I rebooted the endpoint, but now it does not seem to come up again.
False alert, it was just icmp blocked in the firewall so I did not see it coming up again.
After the reboot the resolv.conf is still ok and the system is registered to our platform
(I rebooted the endpoint a couple of times before, which worked fine, there was no other config change done)
Thank you Danny!
Nachricht geändert durch Martin Koch
DNS issues TC5.1.x
So, after you made your changes, the system was rebooted and then was no longer accessible?
A C40 can be accessed via console or via the remote control. You do seem to have root enabled, so you can use console, but that would require on-site presence to connect console cable and PC/MAC. Can you still access the system via On Screen Display menus controlled via remote control?
DNS issues TC5.1.x
Like I updated my old posting, that was just due to a ICMP block.
I am going to send you some more info in a private message.
404
