Does CTS C60 codec require BE 6K
fayiz husain
Hi all,
I have a CTS C60 codec which has to be installed in a new site which has vpn connectivity to the HQ. The HQ is fully functional with a BE 6k, C60 codec, etc.
Do I require a BE 6K in the new site for the installation of c60 codec. (I am confused because I heard that it requires BE 6k sometimes)
Thanks in advance
Yes. You can make inter-site calls, then register your C60 on BE6K from HQ.
For registration BE6K must have one TP room license for your C60.
Recomended bandwidth is  > 1Mb.
Find and read : Cisco TelePresence Administering TC Endpoints on CUCM
br Oleksandr
6 Replies 6
Where would you like to call from your C60.
You do not need a second BE600.
br Oleksandr
I want to make inter-site calls. is it possible with this setup?
br Oleksandr
Do I need any other licenses for this installation?
No. Only one TP Room License for BE6K (BE6K-UCL-TP-RM).
br Oleksandr
what is the bandwidth requirement for intersite calls? (I couldn't find it in the datasheet)
