Does E20 work as a standalone?
Dear support,
is it possible with an E20 to make point to point calls without being connected to a bridge?
So can you connect it to an externally configurated IP adress (for instance a 150-T on h323)?
1 REPLY
Frank,
As of TE4.1 Cisco introduced H.323 support in the E20.  The E20 if fully updated can now be a standalone H.323 codec.
Justin
Thank you, Justin Ferello Technical Support Specialist KBZ, a Cisco Authorized Distributor http://www.kbz.com e/v: justin.ferello@kbz.com
191
