EDGE: After deleting the Unified CM servers from VCS 8.1, TLS is not deleted
Hi All,
I have removed the UnifiedCM servers from VCS 8.1 configuration, and I can see that AUTO created ZONEs for TLS are not deleted.  Consequently when I add Unified CMs to the Unified Communications again, I receive the following error:
Failed: Unable to communicate with cucm-pub.domain.si. PutXmlFailed: putxml failure, no ID returned, response="<?xml version="1.0"?>
<Command>
<ZoneAddResult item="1" status="Error">
<Cause item="1">46</Cause>
<Description item="1">Name already exists</Description>
</ZoneAddResult>
</Command>
I can see that the "Currently found Unified CM nodes" shows my PUB and SUB server
cucm-pub.domain.sicucm-pub.domain.siTLS / TCP9.1.2TLS: Unknown, TCP: Active
cucm-sub.domain.sicucm-sub.domain.siTLS / TCP9.1.2TLS: Unknown, TCP: Active
, but when reviewing the Status / Unified Communications the error is displayed:
Unified CM serversThere are no Unified CM servers configured.
Restart of both VCS-Cs did not resolved the issue. Any clues?
1 REPLY
After the restart I can select the publisher and choose "Refresh servers" and I get "Success: Address lookup for cucm-pub.domain.si succeeded, Unchanged: cucm-pub.domain.si, cucm-sub.domain.si". And then the error from Status / Unified Communications is gone.
The question is why the TLS zones are not deleted after deleting UnifiedCM configuration?
203
