Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Editable quick reference guides
At work i'm responsible for our customer training on the Teleprecense equipment we sell. We always give our customers a quick reference guide for the remote. Like theese:
http://www.cisco.com/en/US/products/ps11386/products_user_guide_list.html
However i would like to edit theese in indesign with the correct fonts and so on. But i cannot find the resources, that would be a very valuable resource for us as partners to Cisco. We would for example like to add our contact information in the same font as the rest of the text and i would also like to edit some of the information boxes to fit some more useful information than the original. I would also like to translate it into Swedish.
I wonder if there is any link to that kind of resources on the Cisco website or if there is any other way to get a hold of those files needed?
1 ACCEPTED SOLUTION
Re: Editable quick reference guides
Michel,
These files can be requested and you have been contacted offline by the person who can provide these.
Thank you!
Paula Talamo
Michel,
Thank you!
Paula Talamo
Paula,
Could I be provided with the same documents too.
Thank you,
Justin
Thank you,
Justin Ferello
Technical Support Specialist, ScanSource KBZ
Hi Justin,
I have forwarded your request and you should be contacted through email.
Thank you,
Paula Talamo
Paula,
I have not heard from anyone on this, can you check for an update please.
Justin
Thank you,
Justin Ferello
Hi Justin,
Please check the PM I sent you.
Paula
410
